Fast PoE minimizes the PoE controller recovery time in case of a power failure. With Fast PoE, the PoE controller initializes the moment the switch powers on, which results in a faster recovery period.
Perpetual PoE provides uninterrupted power to all connected devices during a switch reboot.
Important
Important
  • After you enable Fast PoE or Perpetual PoE or both, you must save the running configuration file.
  • If Fast PoE or Perpetual PoE are enabled and you change global or port-specific PoE configuration, you must save the running configuration file.
